Altium Net Ties in internal Layers
cheece2001
Junior Member level 1
How do I put a net tie on Layers 2 of my 4 layers board.
This is how I have it:
Signal
GND
VCC
Signal
I want to tie all the different grounds on the GND (Layer 2) at a certain point and Altium is not letting me put my Net Tie on Layer 2.
How do I do this?
Or do you not use net ties for grounds at all and just have them all the same net name but different symbols to represent each different ground.
Hi Cheece,
Double click on one of the pins on the net tie. Select what layer you want the pad to be on. Do the same for the other pin. You can now pour the planes around the pins. You can leave the silkscreen on the top layer so you know where the tie is after the board has been made. Hope this helps.
Rick
You can create the net-tie on the top layer (the SMD pads), place it on the PCB, move the pads to the internal layer and copy/paste that net-tie to the library. It will copy the internal layer as well.
Rename the new net-tie as you wish.
