rambito
Newbie level 2
I have a circuits that contain a sheet symbol with the Repeat(sheetname,1,50). Inside sheet symbol there are a shmitt trigger inversor that belongs to SN74HC14D, six shmitt trigger inversor. Each circuit only needs to use one of the inversors. In the PCB, the first channel has the first part (U1A) of the SN74HC14D but the next circuit hasn´t the second part from the component; instead, the second channel has the first part (U2A) of a second SN74HC14D.
I wanna use all parts that belongs to a SN74HC14D and Altium uses a new components for each channel.
Do you know how solve this problem? It has to be something that I am just not seeing!
Thanks, and regards
Thanks, and regards
