Altium issue: Placing net name
bloke203
Member level 1
Member level 1
UK
Hello All
I know how to place net and its name. But I want to make it efficient. What is happened? When I rujn a wire from pin 1 or 2 of IC and left it unconnected to the other end. Then, I place a PORT to the other end and named the PORT say "XYZ".
Do I need to place a explicitly go again to the (PLAce--NET) and point it to the wire for "XYZ"? Becoz when I hover over the wire, it does not show "XYZ" until I go again to PLace -- Net label
It seems that doing extra effort for similar thing. I have to send the netlist to the PCB layout and I need to assign specifically to collaborate with them.
Thanks
Regards
Bloke203
even if you provide net label only it will connect nets with same net label you do not have to provide port for that
I am placing port just for the readability. The question is that if I place a port and give a name, why shouldn't it become a default net name and become visible to it?
Thanks
What I have understand of ports in Altium is that they are used for hierachicl connections to top sheet.
If you do not want to use net label than you can to use off page connector(exact name I do not remember but it looks like "->>" and "<<-").
This depends on whether the project is set up hierarchically or not. A top sheet is not a requirement. If a top sheet is not used, ports can be used to connect from a schematic sheet to any other sheet.
You are correct though that Altium expects you to use net labels for on-sheet connections. The symbol that looks like "->>" is called an off-sheet connector. I don't think it really solves the original question.
I find it myself. It is under the Project --> Project Options --> Options Tab. there is need to TICK the box named "Allow Ports to name nets".
