Altium: Is it possible to combine two different schematics into one schematic?
kahlenberg
Junior Member level 3
AT
Altium: Is it possible to combine two different schemtaic into one schemtaic?
I want to design a PCB wiht two friends of mine. Can I combine 3 schematics into one schematic later?
Is it also possible, if we design PCBs as well, to combine 3 PCBs into one PCB? Of course, same layer numbers etc.
Thanks.
Re: Altium: Is it possible to combine two different schemtaic into one schemtaic?
At least for PCB drawings, Altium do supports multi-user access, have a look here:
While this is possible, is it a good idea to do so?
Any decent PCB program is going to automatically restrict you from using the same reference designator twice.
So if each board has an R1, a C1 etc then its going to cause you problems.
If your just thinking of the production side then consider combining the Gerbers instead.
