Altium help....Altium Users & experts HELP
kazzarian
Newbie level 3
Newbie level 3
I am completely new to Altium infact to PCB Designing.
I have very little experience in Protel 99SE.
Have designed boards in Protel. But i never used the concept of schematics in Protel, i directly placed footprints on the PCB, routed manually and that's it.
Now that i am using Altium, i discovered that i am unable to route manually like i did in Protel without Schematics.
I just wanted to ask, is it possible to route in Altium without anything else like schematics and stuff.......
can i do it just like i did in Protel99SE
you should be able to do it. instead of using the place route you need to use place track command, and turn off the on-line drc..
after you are done with the board you can create a netlist from what you have created.
Where is the Place Track command located, i can't find it..........also tell me how do i turn off the DRC..........a step-by-step guide would be highly appreciated
