altium errors (net xxx only have one pin)
arr_baobao
Full Member level 2
Full Member level 2
altium error ( net xxx only have one pin)
Hi all,
I have encounter this error in altium pcb design when i trying to compile my project.
what does all the errors means? and how to solved this error?
Is this a fatal error or i can just ignore and proceed to PCB layout.
thanks.
Re: altium error ( net xxx only have one pin)
It looks like you've got pins with nothing connected to them. Only you can tell if that's correct or not.
These are single pin nets, means that these conncetions starts from U1 pins but donot connect to any other pin.
If these are deliberate then you can ignore them.
Altium provides a specific directive which tells DRC tool to ignore them when compiling project. Just click on menu : Place>>Directive>>Generic NoERC and put it at the unused pins.
