Onedust
Junior Member level 2
Hi all,
I have a problem with Altium. I've been googling for a few days, tried to look in all Altium's preferences - couldn't solve it.
My problem: When I drag a component, I can't flip it (X, Y buttons) or rotate it (space button). I know that you need to click with the left mouse key on the component, then WHILE dragging you can press X, Y or space, BUT it doesn't work. What is really strange - it worked before on previous Altium 10.
What actually happens is that when I'm selecting a component, I can see the selection highlighted on the component.(Green small boxes around corners of the component - just normal left mouse click on the component), but when I start to drag it, it disappears and I just drag a component without any selection. Before it was still selected and I could edit it, but not anymore.
If someone had this problem and solved it, please share your solution, since it's really annoying not to be able to rotate a component while moving it. You can't adjust it.
thanks in advance,
Den
thanks in advance,
Den
