as nodes they all are the same node as your image shows and its name is p5v main the separation usually done in the PCB design . if you to separate two or more power source you should separate between them by name and circuitHi,
I have a hierarchical style design-which means power ports are global.
I'm getting the duplicate net names on one of my power ports (not all of them-just the one). And I'm not sure why?
Its a custom port-but so are my other ports. What would make a port throw this error?
Thanks.
