Altium Drill drawing layer
xzsawq21
Junior Member level 1
Hello
I want to generate gerber files in Altium
I could placed drill table in drill drawing layer but how should I show drill guide like below?
actually I need it to generate a Fab Layer.
Thanks
I'm not quite sure what you're asking but if you're asking how to generate a drill/fab drawing, the way I do it is by using an .outjob file. Here, you can set which layers you want to use to generate your fab drawing. There's a bit of a learning curve, and the whole think is pretty clunky and non-intuitive (like much of Altium) but in the end it's probably worth learning how to use outjobs.
The other way to do it is:File/Fabrication Outputs/Drill Drawings
Not sure why you want your Fab drawing to be a Gerber.
I have generated the greber files as you are told. but my problem is:
in the FAB Layer there are stack-up, drill table, drill guide, some texts
How should I show drill guide symbols on the PCB? as you see with some red symbols in the first pic.
That's why you use an outjob. you select which layers you want on your drawing, and which ones you don't.
It's still not clear what you are asking. What do you mean "show drill guide symbols on the PCB"? You've got arrows and checks and I don't have any idea what you're trying to convey.
