[SOLVED] Altium doesn't save some changes related to soldermask. Bug?
Lucast85
Member level 3
Member level 3
Italy
Hello,
I've a problem with Altium designer during PCB design.
I've finished to design a 4-layer board and I find 2 mistakes. See the below image:
  1. In the top-left red circle there's a lack of soldermask. The black block is an heatsink and the footprint of the heatsink is composed by many vias and two copper regions (one in solder layer, the other in component layer). I set-up a soldermask expansion in the component side of the footprint to fix this problem and leave a region without soldermask under the heatsink. All goes well (see the second image, marked as "OK!!").
  2. In the bottom-right red circle there's a lack of soldermask in the copper polygon pour on the component side. But...why? I fix it rebuilding the polygon. As second image shown all goes well.
Finally I saved all the project's files.
When I open the project again, it seems the changes were not saved. Why?
P.S. Other changes instead were correctly saved!
Anyone can help me? Maybe a bug or I did something wrong?
Thank you all!
Are there any primitives on the top solder mask layer? When exactly does the solder mask cutout appear?
If you export gerbers, are these correct (i.e. perhaps it is a 3D rendering bug)?
NO.
Every time I open Altium designer by clicking into Altium's icon on my desktop (last workspace is opened) after a saving of all files (with a correct soldermask) was done.
Yes, they're correct. They reflect the actual (bad) status of soldermask I see in 2d and 3d view of PCB: it isn't a rendering bug.
If I generate the Gerber once I've corrected the two problems, the Gerber are OK. But if save all, close Altium and re-open the project, the soldermask has the cutout zone thus I must fix the problems everytime I open Altium. It bother me!!
Very strange, no idea what the problem is. This definitely shouldn't be happening, so I suspect a bug.
Using new Altium 15 the strange behavior disappear! Probably was a bug...
Thanks for the feedback, and glad your issue is solved!
