Altium designer schematic highlighted all
keen
Full Member level 2
Full Member level 2
hi,
plz simple question, schematic has some sheets, global nets .. the same net on different sheets ..
if I highlight the net on one sheet does means this net will be highlight on this sheet but does not on other sheets, why ?
what I have to do to highlight the same net on different sheets ?
regards M.
Hi Keen,
Net highlighted on a sheet in Altium designer doesnt highlight in other sheets.
You have to highlight seperately for individual Sheets.
Shab
You can get this feature only after you compile the project. After that press 'Alt' key & left click on a net identifier. Now the net will be highlited in all the schematic sheet.
Udhay
udhay,
yah, you are great man , altium is huge ..
After compiling the project, just place the mouse pointer over a net for a few second, a pop up menu will appear & by selecting the sheet, you can navigate to other schematic sheets with same net highlighted
Go to preferance>System>Navigation>Highlight Methodes & mark the Connective graph option. Now you alt+left click the net, you can see a connective graph.
Udhay
