Altium Designer S09 Adding 3D objects
Tabulous
Newbie level 3
Newbie level 3
UK
Hi All,
can someone on here tell me how change/add i 3D object to componets in PCB Layout ?
Basically i have Rs and Cs that are using the standard lib footprints from Kemet and Panasonic. When design is transposed to the PCBdoc there are no 3D bodys for them.
So i what to add it with parts ive downloaded from 3Dcentral, how is this done easily ?
Cheers
Thanks but i know how to create and add them to components when using Library Manager.
What i need to do is add them when in PCB layout
hi
in Sch Editor on properties component you can add 3d model to component
look:
for create 3d model you most use 3d editor software for example:3d studio Max
when you create 3d model you can add this to Mentioned component
