That is not a track,that is drc marker. why that is coming with that much line lengthOpen the ethernet connector from library file
Enable all layers by using menu "Tools" -> "Layers & Colors...". Click on "All Layers ON"
You should be able to view the hidden track by now. Click and delete the unwanted track
To place the mechanical pins, use menu "Place" -> "Pad" to insert a pad
Hope this helps
-Nishal
