Re: Altium Designer dosn't increment the designator automati
When you make a copy of a component, the software will not increment the designator for you. It makes an automatic copy designator such as C14_Copy1, C14_Copy2, etc.
Automatic designator increment only works when you place the component using the Place Component command.
For copies, you will have to use the Reannotate Tool, or you will have to manually change the designators.
