Altium designer 6 flipping the PCB top and bottom
Beenaplaye
Member level 2
Member level 2
Belgium
Hi guys,
I want to see the components I 've placed at the bottom of my PCB.
How can I flip my PCB or filter the bottom components from my PCB?
regards
To flip the board : View menu -> Flip Board
To filter the view use the shortcut l (l for lion) select the layers you want to view and disable the others
eg : to view bottom side (select only Bottom Layer, Bottom Overlay, Multi Layer, Mechanical 1, Bottom Solder etc. and deselect others [Keep SYSTEM colors untouched unless necessary])
Nishal
you can also flip your board by RMC on the colour palette displayed in the bottom of screen and selecting flipped option fron the pop up
