fala
Full Member level 5
Hello, I'm using altium designer 6.6 for auto-routing. sometimes I define some rules that are pretty hard to satisfy so after a great percentage of routing had completed I have to stop the autorouter, redefine rules with more relax restrictions, lock previous tracks and run the autoroter again to route the remaining nets. for example I want my power track all be in bottom layer and all be 50 mils as long as it is possible. Obviously it is impossible for a very complex board with many hundreds of nets, so somewhere I have to give in and allow routing to be done also in another layer.
the problem is, when I want to re-run the autoroter some tracks that had been partially routed in previous routing session inhibit new routing success. I want to un-route them but it is impractical to do this by hand(it takes hours) and even so, small parts of some tracks may remain unseen under pads or other tracks. I usually select 'rip-up violation after routing' check box but it seems because DRC dose not regard them as violation they do remain. how can I select partially routed connections and un-route them??
one thing else How can I create a net class in PCB. I want to group some neighbour components and define some rules for their width and other properties. I tried TouchesRoom and WithinRoom but they return components and pads and tracks not nets and in rules for defining width I need to have a net class. Is it possible that I Have a special width rule for some parts of PCB e.g within a room?
Thanks a lot
Thanks a lot
