Altium Design Schematic Library
Tusharsinh
How can i merge more than 2 schematic library into one schematic library in altium designer software.
I've tried to merge schematics in a simulator other than Altium. Here is the only method I am able to work:
1) open schematic #1 in the simulator,
2) save it all to clipboard,
3) Open schematic #2,
4) Paste schematic #1.
5) Both schematics appear side-by-side, unconnected.
Parameters need to be examined afterward, to check whether a circuit's parameters were kept.
Unsuccessful methods include:
* trying to merge netlists in word processor.
* open two simulators, copy and paste from one to the other.
1) Open schematic library 1 -> right click -> select all -> copy
2) Open schematic library 2 -> right click -> paste
Done. Same for PCB library.
Thank you so much for your response.
But what if we want to merge more than 10 schematic library at a time.
Is there any way ??
I do not know any "automatic" way. But it takes you about 3 seconds to perform what I said. So, 20 schematic libraries in 1 minute.. it is not that long time.
the answer is you can't.Altium only supports one file per project for pcb.You can create many documents by adding schematic but it will confuse to use which is best
