altium design for pcb design
Rujul Desai
Junior Member level 2
Ahmedabad
i want to generate netlist in altium for layout and also generate gerber data.
so please suggest it.
Thanks.
For the netlist, select any schematic file, then menu Design => Netlist of project and choose the format you want.
For gerbers, go to File => Fabrication Outputs => Gerber Files OR add an Output job file to your project and select Gerber under Fabrication Outputs, then click "Generate outputs"
