geossj5
Newbie level 2
I am designing a 4-layer PCB:
Signal
5V
GND
Signal
I am trying to use thru-hole vias to connect from a signal layer to one of the internal layers, for example, from top layer to 5V. How do I do this?
I know I can set start and stop layers in the via properties, but that creates a blind via, which are expensive so I would like to avoid it. Is it even possible to have a thru-hole via only connected at specific layers?
I was planning to just setting start layer as top and stop layer as bottom and just specify the net as one of the internal layers. Does this physically only connect at those layers or is there more work to be done to accomplish this?
Signal
5V
GND
Signal
