drx
Newbie level 1
Hello all, I am creating a Pcb with Altium Dxp for the first time.
Simple issue: The default clearance rule on the board specifies 8mil. See here:
This is fine for everything on the board except for some nets which will carry higher voltage, for which I would like to set the clearance to 16mil. I have created the following rule. The nets are listed in the 'First Object...Query' box:
This new rule is set with higher priority than the first rule:
In my current understanding of Altium's rule system, I thought this would require any copper track attached to one of those nets have 16mil of clearance to any other object (with different net). However, the clearances for these tracks still seems to be 8mil:
In the upper right of the editor window, the 'TESTOUT-' track is passing by at less than 10mil from the other pad... and checking the 'Applicable Binary rules' for these two objects, only the default clearance rule shows up.
I'm new at this, so hopefully it's just something easy I missed... Any ideas??
Thanks in advance!!
Thanks in advance!!
