vixo
Newbie level 6
Hi, I've made a multisheet design in altium, but on compiling I get some errors - Duplicate Bus Names Bus Slice. My design has a top sheet(sheet1), which contains four subsidiary sheets(sheet2), and each of those four sheets contain sixteen copies of a third sheet(sheet3) - hope that's clear.
The error seems to be occurring because the four sheet2s have a bus inside them, and when that bus is duplicated it isn't automatically renamed something which distinguishes it from the other sheet2s - Im guessing this because I get the error three times, so the first instance the bus is named and the further three times the sheet is duplicated creates errors. If i increase the number repeats to 5, i then get four errors. These are the only errors I get, so all the nets and components have been renamed ok.
The top sheet also contains a net and this causes no problems, so I suppose the naming of the nets works ok. The project net identifier scope is set to automatic, and seems to have defaulted to hierchical as this option give the same errors.
anyone have any idea why this is happening?
