[SOLVED] Altium adding supplier problem
ctzof
Full Member level 3
Full Member level 3
Munich
Hello,
I have a problem with Altium 16.0, and I cant add any supplier (the list is empty) in data management although I am connected and I can use to Altium vault. Has anyone encountered a similar problem?
Very strange, does the problem also exist in earlier versions (i.e. AD15)? Can you retrieve parts from the Altium Content Vault?
Actually I found it. I had first to install the extensions in Extensions and updates. Everything works now.
