Altium add margin in polygon for Route tool track
xmen_xwk
Full Member level 3
Full Member level 3
I have a polygon on each layer of entire pcb and if I have a hole in the middle of polygon, Altium automatically creates a space/margin from hole to polygon. Very nice, but I want to do the same with Routing tool track on a Mechanical layer, I can use Polygon cutout, but thats needs way extra work to walk around the tool path with a margin. Also, Tools > Convert > Create Cutout from selected primitives just creates the outline of path, but there is no margin. And problem with Cutouts is that, they need to be on each layer. Only way I can think of is a trick, that first I make a thick track, then create its cutout, then reduce the track thickness. But thats just too much manual work for each route or need to do again if there is an update to the track.
Is there any way I can do what a hole does ?
PS : Dont want to use slots.
