buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 962
- Helped
- 40
- Reputation
- 82
- Reaction score
- 24
- Trophy points
- 1,298
- Location
- Florida, USA
- Activity points
- 9,143
cap footprints
hi.
My new problem about resistor/capacitor footprints in altium designer 6:
-If i assign a 0603 (or other) footprint from an old (dxp2004) library to a components, and then put onto the pcb (design>import changes...), then the component will be only 2 pads and a text. The original line around the component is not visible any more. So, if i put 2 resistor next to each other, then we can not see that which pad is for which component.
-I stared using the new footprint libraries. it seemed good, because there were small lines between the pads, signifying that those are for the same component. BUT, the footprint names ar bed: for example for a 0603 resistor: RESC1608L. The peaple who will do the purchasing, and the factory will not be able to recognize that what size is required. Everyone in the world uses this: 0603 to signify the size, but the altium started using a new method: 1608
-In the new library, when i add the footprint, it signifies a long name for the footprint: RESC1608L-0603... but later the end will disappear. Even if i make a BOM, or just want to check in a sch/pcb document.
So, what is the solution?
why the new protel removes the line around the components? how can I take it back?
or how can i take back the lost footprint name ending?
hi.
