Altium 15.1 - Assign solid region to a pad - Shortcut error
diamadiss
Member level 1
Member level 1
Hello,
I created a custom footprint for an inductor and I placed on each solid region a pad. The problem is that when I place this footprint on PCB file the Design Rule Checker shows me a shortcut violation (attachement picture). I try to solve it with "design -> netlist -> update free primitives from component pads" but doesn't work. Does anyone know a way to solve this from the PCBLib file where I created the inductor's footprint? Thanks.
Thanks fot the reply, but I have already seen this post "the command you are looking for is called "update free primitives from component pads" on the pcb side. look under >>design >> netlist >> update free primitives from component pads." but this suggested solution doesn't work in my altium.
