[SOLVED] Altium 14: modify or delete a board cutout
leotordo
Newbie level 2
Newbie level 2
usually when I need a board cutout I design in a Mechanical layer the primitives, then I select them and I use Tool-->Converto-->Create board cutout from selected primitives. All works well.
Now...a squared board cutout that I've on my board must enlarged and be modified in round shape.
How to modify or delete an existing board cutout?
thank you
regards
Stefano
The board cutout is on the "multi-layer" layer. It's drawn like other polygon cutouts with a dashed perimeter line that is the same color as your multi-layer color. As long as you have the multi-layer layer on, you should be able to click in the middle of the board cutout to select it. If the object select list pops up (due to multiple objects intersecting the area you clicked), it should be in the list as a PolyRegion with the description of "Board Cutout". Once you have it selected, you can modify or delete it as necessary. In your case, you'll probably just want to delete it and create a new one (using the same method you used previously). Or you can use the modify outline vertices option for the existing cutout, but that can be tricky.
Hopefully that is clear. Good luck.
