svia
Member level 3
Hello
I have a project altium design all ready done, that was supposed to work. It was for a 4 layer, and I want to do a 2 layer, so I want to redo the PCB. The schematic compiles without errors. It's a design with a top sheet, and 3 other sons sheets.
I create a PCB, save it, I think up to here everything was correct. Then I select Design>Update PCB Documents
It shows the Engineering Change Order screen. First I validate changes, and everything is OK, next I execute changes and error in 4 components, the four components are all connector more or less the same kind, and the message was:
"components failed to add". I say OK, and I close.
Finally what I get is this: rooms are empty, and there is a far point with all /many of the components, all in green.
Any help?
Any help?
