HighTechPower
Member level 5
Hi I'm searching for an easily available IC like MM74C926 with exception that instead of incrementing the counter using CLK, it takes BCD input and display the numbers. The issue is it should be 4 digit display like the mentioned IC but latch BCD data on correct seven segments, out of those four, using some input logic.
