Alternate clock edge detection
How about something like this?
Rising edge triggered D type and two and gates?
D type wired as a divide by two with the Q and *Q outputs anded with the clock to give even and odd outputs that are the same width as the clock (There might be a slight glitch due to the prop. delay of the D type).
Nick deans circuit does not match the clock timing and in any case if that is all that is required a simple D type /2 is very much easier.
Regards, Dan.
Regards, Dan.
Thank you Dan, Can you be specific about how circuit schematic looks like for a D/2?
Google "d type divide by two", it is about as simple as it gets.
Dan.
