Alpha-meric Locators in Altium Schematic
PCB Designers
Member level 3
Karachi, Pakistan
Hi all,
How to do the following in Altium Designer Summer 09 ?
There are many ways to show what page(s) the signal continues to/from. The one is to use the
alpha-meric locaters on the titleblocks of each page. We would then wind up with a name like 3B2. This
would mean that the signal continued onto sheet ‘3’ and quadrants ‘B’ and ‘2’. This may seem a bit cryptic
at first, but will later prove itself useful when trying to locate that elusive signal. It also makes discussing
the schematic over the phone (or through e-mail) far easier.
I used a schematic of White Fin with the same technique used in that. Now I want to do this in my designs on ALTIUM.
Looking forward.
Regards,
Maqbool
The command is under Reports >> Port Cross Reference. And in the Schematic - General Preferences you can set how it is set up.
Maybe you need to compile the project in order to update the locations.
I am running Altium 10 and I only need to execute the >> Reports >> Port Cross Reference >> Add to project and it will update the new location.
Yes, after posting the Question, I just found it by searching it on internet. I checked and verified. Then deleted my question, mean while you helped me again.
Thank you Dear a lot.
Best Regards,
Maqbool
