Allgro PCB, thermal via
kovibb
Member level 1
Hi everybody,
Please how i can add thermal via to thermal pad in Allegro PCB work in package regime? Thank you for advices
Use Route command and than double click to add via during footprint creation or you can use multiple drill option in Pad Designer.
Reactions: kovibb
    kovibb
this is exactly what i want to know. I have one more question for you. Can you tell me how can I create thermal via in Pad Designer? What all must defined in begin layer? How size of pad in begin layer I must set when it be embedded in thermal cooper die pad?
thanks
size is defined in the datashhet fot thermal pad it also gives the details of drill for thermal via
Hi kovibb,
You can't create the thermal on "Pad Designer" directly. First you create the thermal seperately, after that you can add in "Pad Designer".
