Algorithm for 8bit/4bit division in spartan 3 FPGA?
david90
Advanced Member level 1
fpga division
How do you divide an 8 bit number by a 4 bit number in Spartan 3 FPGA. Division is not synthesizable in spartan 3.
Added after 1 hours 27 minutes:
I've found the algorithm but i'm not sure how to code it in verilog. here is the alg
First version of division algorithm and hardware
This is very similar to what we do with pencil and paper. Four registers and a 64-bit ALU are needed. The initial values are as follows: The upper 32 bits (Dh) of the 64-bit register D contains the 32-bit divisor; the lower 32 bits are zero. The 64-bit remainder register R contains the dividend (the upper half is zero). Q, the quotient, contains zero. Here is the division algorithm
Repeat 32 times:
1. Divisor shift right 1 bit, D = D >> 1.
2. Subtract D from R, R = R - D.
3. Quotient shift up, Q = Q << 1; If(R>=0) Q0 = 1, else R = R + D.
Here's my code
module division(clock, divisor, dividend,quotient,remander);
input clock;
input [3:0] divisor;
input [7:0] dividend;
output [3:0]quotient;
output [3:0]remander;
reg [3:0]quotient;
reg [3:0]remander;
reg [7:0]temp;
always@(posedge clock)
begin
temp<=divisor<<4;
quotient=dividend-(temp>>1)
quotient<=quotient<<1;
if (R>=0)
else
quotient=dividend+(temp>>1)
end
endmodule
I don't think it is correct though. I'm just confuse about squential logic.
Added after 1 minutes:
I understand the algorithm but I don't know how to code it in verilog sequential logic
fpga division algorithm
use coregen of xilinx ise software to generate a divider
division spartan 3
Division is synthesizable in Spartan-3, but it's not synthesizable by the ISE 8.1 Verilog compiler.
What kib means, instead of re-inventing the wheel, you can launch CORE Generator (it's included with your ISE software), look under "Math Functions", and you'll see "Dividers" and then "Divider Generator". Use it to create a division module that you can drop into your HDL project.
division fpga
oh. Ok. But if I want to make my own module. I just want to learn how.
