[SOLVED] Air dielectric strength for high power patch antenna
Andrew77
Member level 4
Member level 4
Rome
I'm developing an high power 150W collinear patch antenna for 2,4 Ghz made of 1mm thick patches on air separated by 5mm gap. Between patches @2.5 mm I put probes and simulated: these are the results: more than 30KV/m ! There could be corona effect, considering air strength of 50V/m every mils (for 5mm should be 10000V/m)??
Many thanks
Write your reply...
LaTeX Commands Quick-Menu:
