GaryB
Newbie level 3
I am trying to control my central air-conditioner by dew point instead of temperature.
I would like the air-conditioner to turn on at a dew point of 55 degrees Fahrenheit and then shut off the air-conditioner at a dew point of 50 degrees Fahrenheit. This means a latch holding the air-conditioner on would occur at dew point 55 and the latch would be broken at 50 degrees Fahrenheit. This pattern would happen repeatedly and it would keep the dew point between 50 and 55 degrees Fahrenheit.
I found a dew point transmitter that outputs the dew point level in the 4...20mA = 0...80°F format. This would mean every mA of current would represent a 5 degree change in dew point. This would mean my latch turning on the air-conditioner would occur at 15mA and the latch would be broken at 14mA.
What would be the easiest way to accomplish the set-points of 14 and 15 mA? I could use a resistor as a load, go through an optic-isolator, and then use a couple compactors, then latching relay and another relay to break the latch?
Is there an easier way?
