novicevlsi
Junior Member level 2
beat burst axi
HI
kindly help me out......
In AHB/AXI protocols if the size of transfers is less than the bus width (narrow transfers), for example , if it is 1byte transfer on a 32 bit bus and offset address is 1 , transfer is on second byte lane (AHB). (Little Endian)
similarly for 32 bit transfer on a 64 bit bus trasfer starts on 32-63 bits (from 5-8 byte lanes in AXI) . (little Endian)
pleae refer AHB & AXI for more specific description.
i want to know the reason for these specific Byte Lanes specification.
please explain for Burst cases . Also what about the Alignment ?
when does this narrow transfer case arise....?
thank you so much.........
HI
