After migration cdb2oa missing amount of fingers
cyrus75
Newbie level 1
Newbie level 1
I have mirgrate a library from cdb to oa. This works fine but after resimulation we get different results as before.
First I compare some device if the no of fingers and multiplier are correct converted. That looked ok for
some devices. But then I generate a netlist and find out that the no of fingers is not seen in the netlist and the transistor
has only the width of an one finger device. After changing the no of fingers in the property window from 2 to 3 (or other value)
and back to 2 changed the number of m (multiplier) to right value. Does anyone knows such a problem and have a solution without
touching each transistor a change the values? Maybe a skill code?
