zainka
Full Member level 2
Hi
My summer project this year will be an Aeroponics based greenhouse. Very basically this means that the roots of the plant you are growing suspends into thin air only and for the plant to get its nutritions you have to spray it as a nutrition rich water solution onto the roots using micro foggers (drip water systems) or similar either at low or high pressure,
Now, having control on the nutrition levels, water conductivity, ph and oxygen level in the water sprayed onto the dangling roots is the most crucial point to have at-least some success. Not to much and not to little. That calls for some electronics You may read more about these requirements here and here if you think this is interesting.
What I would like to hear about from you is if you know about other DIY project, or if you have some similar projects yourself, where making ones own electronics is part of the project etc. Especially I need to investigate more on sensors for measuring EC or epsom salts, magnesium and calcium nitrate, in addition to oxygen and Ph. Also, how do one determine if the water has been contaminated? (I guess that calls for extra sensors.) . I wanna do my own HW cause I believe that this will be the most efficient way to learn the most and in addition its fun.
Thanks in advance
Thanks in advance
