[SOLVED] Advice on writing a library/class for arduino, what to do/not do in the constructor?
David_
Advanced Member level 2
Sweden
Hello.
I do not know much about C/C++ but I am trying to make classes for my data converters that I use with my arduino Due, and why not then put each class in a library.
I want to ask about the following:
MAX5216::MAX5216(int CSpin)
  _CSpin = CSpin;
void MAX5216::begin()
  // MAX5216 DAC Setup
  // MSB first, shifts data on SCKs falling edge, clock idle Low, SCK freq « 50MHz.
  SPI.begin(_CSpin);
  SPI.setBitOrder(_CSpin, MSBFIRST);
  SPI.setDataMode(_CSpin, SPI_MODE1);
  SPI.setClockDivider(_CSpin, 2);
Is it any meaning in doing almost nothing in the constructor and then initialize everything in a begin function?
Is there a reason to not put everything that is in MAX5216::begin() into MAX5216::MAX5216(int CSpin)?
Regards
I am aware of the things I need to do in order to use the SPI library inside my own library.
I can't find any difference what so ever in putting a lot of functions or peripheral setup routines in the constructor and I guess the idea is to do it that way. And to have a destructor as well but I have never seen a destructor being used in a arduino related subject(but I have not even read 1% of the C++ codes that lays behind the arduino scenes.
apart from the constructor and destructor options ,
what would be the final hex code memory size in the c++ implementation ?
