matty111
Newbie level 2
Gday fellers, well I want to learn more about electronics and circuit’s and I feel the best way that I can do this is to make something sort of complex (well by my standards anyway).
I’m a light vehicle mechanic and I currently work in a forklift repair place but have done heaps of work with customising cars wiring and pcs and general s--- and I can solder fine and whatnot so I’m not a complete newb with electronic but not far off.
I’m making a new elaborate snake tank out of an old huge hardwood TV cabinet (which suits it perfectly) and want to put a big wiring system in for many things. I can get a few components off ebay for it all (where’s the fun in that) but won’t learn anything and I know it’s a big ask but would a few of you kind people help me out by drawing a diagram (I can read them fine and know what all the components are) and then help me out by answering my (probably many) questions after?
So here goes.
I’m thinking the best way to do this is via 12VDC and have relays in place for actuating the two 240VAC heat and UV lamps. Obviously circuit breakers in there to.
Firstly I want three temp sensors and three humidity sensors and all displayed on six three number displays.
I want to use one of the temp circuit’s to actuate a relay for a 240VAC 100W heat lamp at an adjustable temp that can be displayed on one of the temp displays when you press a button and another two buttons to adjust it whenever I need.
Secondly I want to have an adjustable time for turning on a relay for the UV lamp in the day and off again at night.
Thirdly I need a circuit that controls 2 separate red led strips that will be on at various brightness at different times all day and night (both strips need to be at a different brightness to each other all the time as one strip will be in a brooding box) and I would like to have them slowly fade in and out when the need to and not just suddenly if not to hard?
Fourth I have 5 3.5V 350mA led’s that I want to run on two circuit’s (one with two that point up and one with three that point down) that need to run only during the day. And I want them to be on at different brightness’s at different times of the day again and different brightness’s to each other again
Fifth I have a 12V 300mA water pump that I want to run only during the day but at a varying rate so I can monitor how much humidity is being made (heaps of water pumped all over the tank will create heaps of humidity which is fine during the winter but not at summer)
I also want 5 pots to vary the brightness of the two red strips, the two white led’s and the speed on the pump and that will just disregard the power the circuits have them at (via diodes?) and to turn the pot all the way off to put them into “auto” mode
I would also like to have two SPDT switches for the UV and heat lamps (on/off/auto) and have a little rgb led for everything so when it’s in auto mode it will be green, blue for on and red for off.
And finally I would like a total wattage display just for s---- and giggles.
If you can help out that would be great as everyone needs to start somewhere.
Cheers
Matt
So here goes.
Cheers
Matt
