NIKI90
Newbie level 1
Hi, I’m Nicola! Good morning to everyone!!
I have to design a board to acquire analog signals continuously (6 ch, resolution min 14bit, sample rate 20KSps for channel, input range:+- 5V). The acquired data must be store in a memory. It should preferably be an SD card.
After that the signal must be elaborated, that is to say signal processing such as FFT, IFFT, convolution…
All the operation must be do on the board!!!!
My idea is use the following architecture:
-A/D module
- DSP / DSC
- SD card
I think about SPI or I2C to interface the devices.
I would ask you some advice about the most appropriate architecture, the best brand for the device and if it is possible an example of the device.
Ask to more information.
Thanks for your attention.
-A/D module
- DSP / DSC
- SD card
