advantage of source degeneration?
rajivbhatia
bangalor e india
source degeneration
hi
i want to know the advantages of using the source degeneration in terms of output voltage swing and settling time or any link related to this topic
thanks
degeneration resistor
Pleaes read p.p.60 (3.2.5: CS Stage with Source degeneration) for details
Design of Analog CMOS Integrated Circuits
Author: Behzad Razavi
You can get the book at:
source degeneration resistor
One of the most significant advantages of the Source degeneration in differential amplifiers is to make the circuit more linear.
Gray's book have also useful information on this topic.
source degeneration feedback
Source degeneration boosts the output impedance, but decreases the usable output swing.
source-degeneration
source degeneration bring more nosie because of the source resistor.
ofcourse, this is drawback.
Reactions: mursri
    mursri
source degeneration
It boost output ac resistance, degenerate mosfet gm and make the gain more linear.
source degeneration inductor
helps input matching maching
helps to achieve better linearity
worse headroom if u use a resistor
if you use an inductor do not affect headroom and helps linearity too
provide series feedback
the utility o source degeneration depends on the circuit that you are using and what aspect u want to improve
Reactions: UI_609
    UI_609
what is degeneration resistor
Reduce 3rd order products
Transforms input impedance to be real instead of imaginary
