ADS Warning via is too long
Amr Wael
Member level 5
Member level 5
Hello , I am performing an EM simulation for a coplanar waveguide on a 1.54 mm thick substrate over a frequency range between 25 to 30 GHz.
I am getting warning "Via in substrate layer 1 is 1.524 mm Long!
Consequences: Reduced accuracy.
Consider : removing the via
splitting up this layer into 2 layers.
My question is why did I get this warning ?
to which extent does it affect my simulations results and what's the solution for it ?
Thank you very much in advance.
