ADS Touchstone S2P to S4P
EM98
Junior Member level 2
i have a question plz, i am working with the touchstone combiner but when i try to import my 4 s2p files to get an s4p file i have the following warning "the following file can not be add this tool support only version 1", any help with that ?
Can you show the contents (ASCII text) of one of these S2P files?
Example file attached...
  • P1P2_s2p.txt
Ok, that says "Version 2" which might be an extended Touchstone format version.
You need to modify your files to the "normal" Touchstone format by removing all control comment lines in [ ], just leave the data format line
# MHZ S DB R 50.00000
The comment line with ! is allowed, if you wish. But remove the [ ] lines.
Reactions: AlexSIC
    EM98
it's works
Thank you for your support.
    AlexSIC
About the the port mapping what does exactely means ?
--- Updated ---
THANK YOU
