Hi
in some case when i want get layout from schematic it doesnt convert correctly
and when i deactivate Msub in schematic it convert only lines (almost correct)
how can i get layout when msub is on?
In the MSUB element, you need to set the drawing layers, parameters "Cond1" etc.
From the gray outline, it seems that the layer set in MSUB does not exist in your layout layers.
