ADS problem during DXF Import!... Help...
ZincBear
Member level 2
Member level 2
Singapore
Dear all,
im having problem with ADS2006 dxf import.
Whenever i import a DXF file into layout, an error message pops up:
"File 'C:\documents' is not a DXF file".
Then another pops up:
"The program had a problem opening the file c:\documents provided as a command line argument. Last line processed 0."
Pls assist!! Thank you all!
I'm having this problem too :(
can anyone help?
Probably you are trying to read the DXF file from a folder under C:\Documents and Settings on a Windows XP PC. ADS does not like spaces anywhere in the path to a file. Copy or move the file to a folder whose path has no spaces like C:\users\default and then it should read correctly.
