ADS Parameterized layout from command line.
goay
Newbie level 5
Newbie level 5
Hi, when I run simulation from ads schematic window using parameterized layout setup, everything is ok and I did not get any error. However when I run it from command line using
hpeesofsim netlist.log
I get the following errors:
RESPONSE FROM COMMAND PROMPT
Characterizing the circuit
Characterizing Tx channel
Error detected by hpeesofsim during TRAN analysis 'ChannelSimTransient_ChannelSim1'.
COMPONENT 'X2.em_data':
Failed to establish a Gemx connection.
Fatal error occured while evaluating model 'MomCmpt', instance 'X2.em_data'.
This only happens when I change the design parameters in the netlist file such as length and width of microstrip. Anyone knows why?
From what you describe, it seems that Momentum is not started to add missing parameter combinations in the emModel. I never used emModels from the commandline, so no idea if this should work at all. Have you tried asking Keysight support?
Reactions: goay
    goay
My school's ADS was sponsored by Keysight years ago and our support has expired. But we are still allowed to use the software. Thanks. I can still use other EM simulators such as Sonnet for that, but I would prefer to use momentum together with ADS circuit simulator.
