winglj
Full Member level 4
ads momentum ground
Hi, everyone. I have a question about the ADS Momentum finite ground plane simulation.
I know that in order to get a good results for the software based on MOM, a infinite ground plane is needed. However, I also want to try the finite ground plane simulation in ADS Momentum.
However, it seems when I defined all the ports as internal ports, no matter whether the Ground reference port is added to a large size finite ground plane or not, the simulation results are abnormal.
I am wondering whether someone has some example for finite ground plane simulation of ADS Momentum or other EM software based on MOM. Thanks.
