ADS Layout
errikosgk
Newbie level 6
Newbie level 6
Hello, I am trying to do an em cosimulation in ADS but when I run the simulation it says that it is finished with errors like in the screenshot below. It says that matrix is singular beween nodes or branches.... but I cannot find these nodes in my layout. Can you help me?
These errors are coming from an active model.
There might have few causes. Either model itself has some problems OR when it's been used with EM simulated board/substrate some convergence errors occur.
OR both..
Nobody can say something without knowledge of simulation setup.
I recommend you to check the board simulation results first, you shouldn't see any weirdness.
OR both..
I checked the model and I can't find something weird
For every capacitor try putting a low-ohm resistor in series with it.
Some simulators require that every circuit have a ground icon somewhere.
Any PNP or Pmos should not receive bias voltage greater than its emitter leg.
Two supply rails (source or ground) must not be connected to each other unless a component is in wire between them.
This is the layout I am trying to cosimulate. Between the pads I have designed capacitors will be placed.
Sorry but this layout is a nightmare.
You have to work on it and Momentum cannot simulate correctly this layout because it has many fundamental errors.( Ports, Transmission Lines) etc.
LaTeX Commands Quick-Menu:
