ADS & CST co-simulate
arash.h
Hi.
I want to export PCBs with active components (ex: BJT, MOS,...) from ADS & import them to CST. Is it possible to co-simulate in this way? How can I do this?
Thanks.
You can export from CST to ADS, but not in inverse order
    arash.h
Thanks Byteptr. But I have to simulate effects of the plane-wave radiation on a PCB with active lumped elements. What can I do?
You can simulate the whole PCB using CST and export the results as a SNP file. You can then use this SNP file to simulate the active circuit with the effect of PCB.
    arash.h
In this way is it possible to simulate interference between plane-wave and circuite lumped components?
It will simulate interference among all PCB traces. I think it is difficult to incorporate the lumped component structure.
