Adjusting LED current by adjusting control voltage...how?
T
treez
Newbie level 1
Hello,
The HV9910B allows you to adjust the LED current by adjusting the voltage into the "LD" pin.
The range of the "LD" pin voltage is from 0 to 250mV.
...this is very low voltage, how could you accurately apply control voltages of 50mV, 100mV, & 200mV to the "LD" pin?
If you use microcontroller, then a digital to analog converter can do this....
DAC can also be used without microcontroller, you have to configure the digital input manually.
Have a look at this...
Reactions: treez
    T
Thanks, but i cannot afford a DAC, so i wish to put a 250mV voltage across the internal resistor of this digital pot, and then use the digital pot to divide down this 250mV voltage
digital pot = MCP4011....
https://ww1.microchip.com/downloads/en/DeviceDoc/21978c.pdf
......the problem is that the resistor in the digital pot is 2K1, and so i am going to have just 125uA flowing in the resistor, so do you think the control voltage will succumb to noise?
